• If you have bought, sold or gained information from our Classifieds, please donate toThe Boogie Board and give back.
Diezel Big Max head with box
Sevenstringer
Central NJ
Brief & Accurate Description of gear/guitar:
Diezel Big Max head
Works and sounds great
Newer JJ tubes installed
In great shape, 2 small scuffs on right top side
Low usage in a studio setting
Pretty versatile for single channel
LOUD
From the Diezel site:
The old-school nature of the Big Max 50-watt amp head is quite a departure for Diezel. Unlike some designs that feature several channels, tone-shaping switches, MIDI, and more, the Big Max’s single-channel construction is purity in its finest form. This KT77-powered amplifier is carefully engineered to take you from our bell-like cleans to Diezel-grade distortion. We feel that benefits such as unparalleled touch sensitivity, the amp’s pedal-friendly nature, and ease-of-use make the Big Max one of the most exciting amps in our history. In a world of unending electric guitar gear options, we think you’ll find the simplicity of plugging into, and cranking up the Big Max a life-changing tonal experience.
● Studio-grade cleans, rock-ready crunch, and searing high gain in one channel
● 3-band EQ and a bright switch are all you need for tonal tweaking
● Carefully chosen tube complement fills your tone with rich harmonics
● Unrivaled touch response allows you to “play the amp”
● 3-band EQ for effortless tonal shaping
● 2 x KT77 power tubes
● Tubes: 2 x KT77, 3 x 12AX7B & 1 x CV4004
● Single-channel design
● 2 x distinct inputs (High/Low)
● Global input bright switch
● Series Effects loop
The benefits of a short signal path
From the very first note, you’ll understand the tonal magic that comes with the Big Max’s shortened signal path. Without a truckload of switches and controls in its way, your notes are free to sing out of your speaker the same way you played them.
50-watts of KT77 power
To get the most from the Big Max, Diezel chose to power the amp with a duet of KT77 power tubes. Well known for their clarity, bottom end, and reliability, the KT77s give this amp plenty of punch for any situation.
Dimensions: 11.5″(L) x 23.25″(W) x11.5″(H)
Weight: 41 lbs.
Modifications (if any):
None
Accessories (hardshell case etc):
Original Box
IEC power cable
Location (City,State or City,Country):
Central NJ
Contact Info (No Phone #s)
PM me here
References (eBay or other forum userid):
I am on Ebay, Jemsite, MetalGuitarist.org, Sevenstring.org, Thorn Forums, HugeRacks, Marshall Forums, VHT Forums, Fractal Forums, Vintage Rocker Birds and Moon, The Gear Page, Harmony Central, RigTalk, Guitar Porn, Reverb.com all with the name Sevenstringer
Price (include currency and if firm/obo):
$1549
Only trades for PRS Guitars of equal value. Local NJ, Philly, NY for trades only
Pictures:
More pics here:
https://postimg.cc/gallery/mMWkc8H
