It is currently Wed Dec 19, 2018 12:00 am
Post new topic Reply to topic  [ 1 post ]
PostPosted: Thu Nov 22, 2018 7:47 am
Boutique builder Mike Lull's take on the Firebird with modern appointments.
Hand crafted by Mike in 2011, the fit and finish on this instrument is beyond compare.
Well-balanced when played standing or sitting, the mini-humbuckers give this guitar a unique tone somewhere between a full-sized humbucker and a P90. Originally came with 2 Lollar pickups, I replaced the bridge with a Duncan Vintage Mini Humbucker for a bit more output:
"The Vintage Mini Humbucker bridge pickup delivers the classic Firebird tone that is a special blend of bright, single coil high end, and more focused humbucker low end. The result is a pickup with a cool snarly grittiness, and enough bite to cut through any mix. Great for big, midrangy chords, or solo tone with an edgy bite.Pair with the Vintage Mini Humbucker neck model for a classic Firebird setup.Hand made in Santa Barbara, CA, this pickup is a drop-in replacement for any mini-humbucker sized route and is intended to be mounted to the guitar using a Firebird style mounting ring and 3-48 humbucker mounting screw. Comes with braided single conductor lead wire."
Neck thickness: 1st fret .85", 12th fret .98"
Guitar is in mint condition and plays like a dream. Not interested in any trades.
$1950 shipped in the CONUS or I can meet someone within an hour of Boston, MA to drop it off.
Mike Lull FX Electric Guitar
The ultimate bad-ass rocker guitar with the Mike Lull flavoring makes our FX a surprisingly all-around-player boasting tones for hard rock all the way to Jazz. Super lightweight and easy to play, simply put, the FX will blow your mind!
» Lightweight, bad-ass and versatile
» Every Mike Lull instrument is hand-built by Mike himself
» Built in Bellevue, Washington, USA - Just outside Seattle
» Every Mike Lull instrument gets a PLEK precision fret-leveling
Mind-blowing versatility in a bad-ass rocker, that's what the FX is all about.
FX Features & Specs
» Mahogany Body With Raised Center Section
» Graphite Reinforced Bolt-on Mahogany Neck
» Madagascar Rosewood Fingerboard
» Contoured Neck Heel
» 25 1/2" Scale length
» 22 Stainless Steel Frets
» 12" Radius Fingerboard
» 1 11/16" Nut Width
» Bone Nut
» Weight = 7.0 lbs
» TonePros Chrome Tailpiece and Bridge
» Kluson-style Tuners by Gotoh
» Vintage Style Pickguard
» Custom Lollar Mini-Humbucker Pickups
» Full Electrostatic Shielding
» Custom-fit hardshell case
