It is currently Wed Dec 19, 2018 12:01 am
Post new topic Reply to topic  [ 1 post ]
PostPosted: Tue Nov 20, 2018 6:18 pm
Splawn Amplification SuperSport Amplifier in Mini Headbox
2-Channel 22-Watt 6V6 head, has custom Solo Boost option (variable level). Very compact, is mounted in a "mini" head box cabinet. Great cleans, and the OD channel can get very chunky, overdriven, and loud. Very usable Master Volume to control overall level and not affect tone.
4 x 12AX7 preamp tubes and 2 x 6V6 power amp tubes
$1100 shipped in the CONUS
Includes foot switch, 25' cable, padded cover, power cable. In excellent condition, never gigged. Built by Scott Splawn in North Carolina.
• 22 watts - w/ 2 6V6 power Tubes
• Channel 1 (clean) - Master Volume, Gain Control, Shared EQ
• Channel 2 (overdrive) - Master Volume, Gain Control, Shared EQ
• 4 Button Footswitch - #1 Clean/Overdrive - #2 Mode 1st Gear/2nd gear- #3 OD1/OD2 - #4 Boost
• Series Effects Loop - w/ true-bypass and adjustable +4db/-10db switch
• Loop Volume Control for low volume playing.
• Impedance Selector - 8/16 ohms
• Mini Headbox Weight 35lbs Dim W 20-3/8" H 10" D 8.5"
