It is currently Mon Jan 21, 2019 8:21 am
Post new topic Reply to topic  [ 1 post ]
PostPosted: Tue Mar 06, 2018 8:20 pm
Hi there!
You are looking at a New / MINT condition Paul Reed Smith PRS McCarty Trem (McTrem) model loaded with the elusive 85/15 pickups with bird inlays with a Wide Fat neck profile.
See pictures here: https://reverb.com/item/10711207-paul-r ... ation=true
This is definitely one of those 9.8 tops that very well should have been a 10-top, look at the pictures... I know most people like to say "used for 37 seconds" or something similar it illustrate low usage. This is one of the rare situations where I bought it and it sat with the cover on it in my den. I only purchased it to collect it and have probably played this PRS for an hour, maybe slightly more. The great thing about guitars, is that they show their condition if they have been used. On this particular one, you will notice no fret wear, dings or chips of any kind. Having said that, there are some polishing swirls that can be found. I say this because I am sure someone has a microscope and will complain about fingerprints or the lack of polished metal appointments. The case is in great condition and has some scuffs from being stored with other cases in a temperature /humidity controlled closet.
All original from factory except for the upgraded 85/15 pickups and the black felt strap rings I like to install between the strap nut and the guitar body /finish. It ships with the guitar itself (duh), case candy, hang tag, trem bar and case.
$2,100 shipped.
NO TRADES - PLEASE DON'T ASK.
