Heathkit IT21 - Decent Tester?
Addictedtokaos
Post by Addictedtokaos » Sun Mar 03, 2013 10:18 pm
Im looking for a tube tester to let me know the life left in my tubes roughly. Would the IT21 be capable of this?
A guy selling one local, says its in working order and willing to let it go for $50. Should I grab it?
ESP Eclipse II w/EMG JH Set
Squier Bullet w/SD SH-2n/SH-6
Mini Rectifier
2x12 Horizontal Cab
Line UX6 w/ Overloud 2
Addictedtokaos
Re: Heathkit IT21 - Decent Tester?
Post by Addictedtokaos » Wed Mar 06, 2013 8:56 am
I ended up grabbing it as well as a crap load of old tubes, some still in original boxes.
The tester is in excellent condition, only had to tighten the plate voltage knob. Other than that it appears to work. Just need to clean it up.
Mini Rectifier
2x12 Horizontal Cab
stokes
Post by stokes » Sat Mar 16, 2013 4:22 pm
That tester is an emmisions tester,wont tell you much beside good/bad.If it has a shorts test or gas test they will be about the only reliable info.
