Mesa IIC+ and STR-415's?
Koadogg
Post by Koadogg » Mon Feb 27, 2012 9:46 am
I have a mesa IIC+ 60W and want to get a set of 415's. I found a decent set of Sylvania 6L6GC STR-415's but need to know what I need to look for to ensure that they will work in my IIC+ without having to bias them. Any information will be helpful.
Thanks in advance!
MrMarkIII
Re: Mesa IIC+ and STR-415's?
Post by MrMarkIII » Mon Feb 27, 2012 5:19 pm
Mesa Mark amps were designed around those tubes.
The only issue might be how much they were used and/or abused.
But I'd bet even old STR-415s are better than most of the stuff available.
Jackie
Post by Jackie » Mon Feb 27, 2012 6:09 pm
If you're buying used tubes there isn't much you can do to "insure" it will work. You can visually inspect it for any cracks, holes, white/gray dust etc. to see if the tube is completely bad or not but that's about all you can do without popping it in and playing an amp.
GUITARS: heavily modded Epi Goth Explorer; Jackson KVMG Pro; Yamaha SG2000; Gibson SG '61 Reissue; Squier CV Tele
AMPS:Mesa/Boogie 2:90+TriAxis; Marshall JVM410H (modded); Marshall 1960A w/V30
FX:BOSS GT-6
Koadogg
Post by Koadogg » Mon Feb 27, 2012 6:45 pm
So long as they are a matched pair, I should have no issue with biasing?
MrMarkIII
Post by MrMarkIII » Tue Feb 28, 2012 1:38 am
Koadogg wrote:So long as they are a matched pair, I should have no issue with biasing?
No issue. It's what Mesa amps are famous for. Or infamous.
Tubes with the Mesa label are matched to the fixed bias of the amp.
tony777
Post by tony777 » Tue Feb 28, 2012 10:36 am
is there a way to measure that the tubes run in the correct range?
http://tonykareid.com
Mark IIC+ SGX, DRGX x2
Mark III black dot DRGX
Mark IV A DRGX
Mark V:25
Dual Rectifier Rev G, Recto preamp
Cabclone
Mesa amp switcher
4x12 Recto standard
1x12 Thiele cab.
Tons of Ibbies, what a habit.
dodger916
Post by dodger916 » Wed Mar 07, 2012 7:17 am
tony777 wrote:is there a way to measure that the tubes run in the correct range?
Yes, but you'll need a tester that will run similar plate voltages to your C+. Many testers top out at 400 volts, or 50 to 60 volts short of the C+. Though you should be safe using Mesa STR415's, tube performance does drift over time.
1966 Fender Pro Reverb
DC-3 head
Orange Dual Terror
