It is currently Sat Nov 17, 2018 9:03 pm
 Post subject: Mark III preamp tubes.
PostPosted: Tue Jan 24, 2012 8:46 pm
Alright all you metal players using Mark III's, what kind of preamp cocktails are you using?
PostPosted: Thu Jan 26, 2012 12:54 pm
For heavy shred everything:
V1 - The nicest, sweetest tube you own.
Everything else - choice high gain chinese tubes. 12AX7B's, and silver specials from the 80's.
1994 Mark III Blue Stripe 60 watt, R2 vol mod
In his house at R'lyeh dead Cthulhu waits dreaming.
http://www.myspace.com/ytwwvofficial
PostPosted: Wed Oct 09, 2013 7:57 pm
I am going to try a GT tube that I have identified as a JAN GE 12AX7WA in the number one, and the Chinese square getter dual post ones in everything else.
Will advise
Mark III Blue Wood n Wicker Combo
Simul-Class 295
ADA MP-1
Single Rectifier Combo
2001 CS C5 Les Paul
1989 Ibanez Jem 7PBK
PostPosted: Wed Oct 23, 2013 8:48 pm
I got alot of old Chinese 12AX7's How can you ID it if it is a Silver Special?
Simul-Class 295
ADA MP-1
2001 CS C5 Les Paul
PostPosted: Sat Nov 09, 2013 8:22 pm
On the silver specials, ALL of the visible internal components look like they are chrome plated.
2008 Triple Rec
Dean '79 V (Dean Tyrant/dimarzio mystery neck)
LTD Ninja 600 (SD Black Winter/59)
Epiphone Les Paul Standard (EMG 81/85
Ibanez GAX70 (EMG 81)
Hamer Standard (Golden Age Hot PAF w/ ceramic magnets)
BC Rich Warlock (L500-XL's)
PostPosted: Sun Nov 10, 2013 10:57 am
I'm using RFT in V1 and JJ's in the other spots, in My Mark III Coliseum blue stripe.
90' Mark III Coliseum blue stripe
95 Triple RevG
96' Triple RevF (2)
04' Recto 4x12
07' Recto 4x12-EVM12L's
09' Mills (2)-4X12-V30
96' Explorer
03' Faded V
13' Government V
PostPosted: Fri Dec 20, 2013 10:11 am
I run a mallard in V1. Makes my purple stripe scream. LPS in the PI and Chinese in the rest. Ive owned 2 Mark IIIs in my days and both were extremely picky about preamp tubes. This cocktail worked best in both of them for my ears.
F50
Mesa and Randall Cabs
Lots of other sh!t too
PostPosted: Thu Feb 13, 2014 11:42 am
What should I put in v1? is Tung-sol good? Or something like mesa's SPAX7?
I'm currently using JJ ECC83S.
If I put a "high gain" 12ax7 as phase inverter, how will it affect the sound?
Has anyone tried Sovtek LPS in v5?
EDIT:
Nevermind, I put tung-sols in v1 and v3 today. I hear improved sustain and overtones, brighter/more clarity, and more cut. But there is slight decrease in gain, and the bass isn't as punchy/tight.
Mark III blue stripe combo
MM JP6
Fender MIJ RI57 strat
PostPosted: Fri Jul 25, 2014 8:53 pm
89 Green stripe simulclass w/GEQ, I play hard rock and metal.
Right now I have Winged C 6L6's
V1: TAD 12ax7
V2: 12ax7EH
V3: Tung Sol 12ax7
V4: Tung Sol 12ax7
Before that I had Tung Sol in V1 and V3 and EH in V2 and V4. First thing I noticed was the high end was rolled off slightly, took some of the hair off which I liked. The low end was also bigger, wasn't getting mushy at all, felt like it was pushing more air. I haven't experimented much but just from this little bit it was definitely a good upgrade.
PostPosted: Sun Sep 21, 2014 1:24 pm
Try an Ei in the V1 position and 8th generation Chinese in all other spots.
PostPosted: Thu Jun 04, 2015 3:28 pm
What's your opinion on SOVTEK 12AX7 LP ECC83 ?
MESA BOOGIE MARK III BLUE STRIPE proud owner
https://www.youtube.com/watch?v=qqZz5rHHIIk
https://www.youtube.com/watch?v=VBXj8AJ108Y
https://www.youtube.com/watch?v=1gejXLj8W-Q
https://www.youtube.com/watch?v=6Eptmr_XaRQ
