212Mavguy
Don't throw those tubes away just yet...clean the pins first. 12ax7 pins can be cleaned with a bit of scotchbrite pot scrubber pad pinched around each pin and pulled off... or a dremel wire wheel in a dremel, holding the tool in the left hand so that the brush rotates toward the tips on the pins. If you use the dremel, wear eye protection.
