Changing tubes, lower gain?
Chadd
Post by Chadd » Tue Aug 02, 2011 12:20 am
Tried this in the recto section, without luck. Apologies for the double post.
I'm looking to re-tube my single rectifier and looking for some specific advice. Currently, it has JJs across the board, as that's how it was when I bought it. I'm looking to reduce the overall gain on the lead channel a bit, but I'm fine with how the clean channel sounds. As far as tonal changes, I wouldn't complain if it had a little more sparkle, especially on the lead channel. I'm not looking to neuter it completely, just make the gain knob a little more useful for various rock tones.
Thanks
Jackie
Re: Changing tubes, lower gain?
Post by Jackie » Tue Aug 02, 2011 6:20 pm
As far as 12AX7s, I find that New Sensor tubes, especially TungSol, to be a bit brighter and conservative on the gain side of things. EH are also great tubes. Just don't put them in the cathode follower position (don't know which one that is in a Recto), they weren't designed for voltages that high. Works fine everywhere else though.
You could also put a lower gain tube in the cathode follower position or other position like the PI, 12AU7 or 12AT7 for instance, but I have zero experience with this, just saying what I saw folks do when they wanted to lower gain on amps in general.
GUITARS: heavily modded Epi Goth Explorer; Jackson KVMG Pro; Yamaha SG2000; Gibson SG '61 Reissue; Squier CV Tele
AMPS:Mesa/Boogie 2:90+TriAxis; Marshall JVM410H (modded); Marshall 1960A w/V30
FX:BOSS GT-6
J.J
Post by J.J » Wed Aug 03, 2011 5:49 am
I'd agree that the Tungsol RI and EH 12ax7 will brighten things up and lower gain. If you really want to significantly lower the gain you probably need to start looking into 12at7s etc. The 5751 could be good too, but I have not tried the New Sovtec version to know.
Triple Crown 50 combo
Express 5:25 1x12 combo
JCM800 2203
Deluxe reverb reissue
crane
Post by crane » Wed Aug 03, 2011 12:14 pm
Do NOT put a 12AT7 in the cathode follower position. That tube has a 90V max cathode to filament voltage, which a cathode follower exceed. It will broke the tube.
Try a 5751 or 12AT7 in V1, it will lower the gain a bit and probably give a more articulate sound. JJ 12AT7 fit well as they don't remove bass like other 12AT7.
PRS McCarty Soapbar with BKP Pigs90, PRS custom 22 with BKP Rebel Yell
Mark V Head, 1x12" Mesa 1/2 closed (EVM-12L)
Triaxis 2.0 noFat - Quad preamp
Deep modded 20:20 - Bias modded 50/50 - SimulClass 295
Home made amps/speakers/pedals
Chadd
Post by Chadd » Thu Aug 04, 2011 3:14 pm
Anyone have a list of what V1-V5 do in a recto? I'm sure it has been posted, but I haven't seen it.
dodger916
Post by dodger916 » Fri Aug 05, 2011 1:05 am
Chadd wrote:Anyone have a list of what V1-V5 do in a recto? I'm sure it has been posted, but I haven't seen it.
Should be here: http://www.mesaboogie.com/manuals/user_ ... tml#gpm1_2
1966 Fender Pro Reverb
DC-3 head
Orange Dual Terror
yeti
Post by yeti » Fri Aug 05, 2011 7:56 pm
i'll say it, cuz i always do.
give the mullard cv4024 a shot as a lower gain tube in v1 or v2.
crane
Post by crane » Sat Aug 06, 2011 3:11 am
yeti wrote:give the mullard cv4024 a shot as a lower gain tube in v1 or v2.
+1
dodger916
Post by dodger916 » Sat Aug 06, 2011 7:37 am
+1
+ 1 more
DC-3 head
Orange Dual Terror
Chadd
Post by Chadd » Tue Aug 09, 2011 1:34 am
I found some old sovteks in an amp I cleaned up and then put in a corner three houses and 18 years ago. Huge difference in the amp, it just sounds so much more musical. Smoother and lower gain right off the bat. I will check into the CV4024 and I already have a couple 5751s on order for this and another amp.
Thanks guys
crane
Post by crane » Tue Aug 09, 2011 12:39 pm
You can find that Mullard under CV4024 or 12AT7WA. It's really a good tube, and if you didn't like it in V1, try it in the PI position : it will remove less gain but really add some clarity.
dodger916
Post by dodger916 » Tue Aug 09, 2011 1:10 pm
crane wrote:You can find that Mullard under CV4024 or 12AT7WA. It's really a good tube, and if you didn't like it in V1, try it in the PI position : it will remove less gain but really add some clarity.
+1. I like it best in the PI of my Mark amps.
Doug's Tubes sells them. http://www.dougstubes.com/catalogsearch ... /?q=CV4024
So does The Tube Store: http://search.store.yahoo.net/thetubest ... earch.html
DC-3 head
Orange Dual Terror
domct203
Post by domct203 » Sun Aug 21, 2011 8:51 am
crane wrote:Do NOT put a 12AT7 in the cathode follower position. That tube has a 90V max cathode to filament voltage, which a cathode follower exceed. It will broke the tube.
+100
The Mullard CV4024 is an excellent PI tube.
Dom
'07 Roadster Voodoo modded
'08 Stiletto Deuce II
'10 Mark V - sold
'18 TC-100
'01 Recto 4X12 Slant
'04 Recto 4X12 Slant/Straight
'74 Les Paul Custom
'95 American Strat
'12 Les Paul Signature T
TC G-System
==> NOMAD on Facebook <==
