Newbie TA-15 Tube question
gibby58
Post by gibby58 » Thu Jun 23, 2011 2:18 pm
I bought a demo TA-15 from Sweetwater. I'm loving the amp, but I had a Preamp tube go microphonic on me. I ordered a set of Tung-Sol's. I've read good things about them. I bought 4, but in the TA manual it says not to replace all the tubes at once. I've never heard of this before. Is that right?
Thank you in advance
dodger916
Re: Newbie TA-15 Tube question
Post by dodger916 » Fri Jun 24, 2011 12:48 am
gibby58 wrote:I bought a demo TA-15 from Sweetwater. I'm loving the amp, but I had a Preamp tube go microphonic on me. I ordered a set of Tung-Sol's. I've read good things about them. I bought 4, but in the TA manual it says not to replace all the tubes at once. I've never heard of this before. Is that right?
If it's in the manual there's probably a good reason. Does it so why?
If you replace all tubes at once you're probably discarding good tubes. When dealing with a microphonic preamp tube, the commonly accepted procedure is to tap lightly on each tube with a pencil eraser while powered up to find the bad one. Another way is to replace each tube one at a time with a tube known to be good until the noise goes away. This way you'll isolate the bad tube.
1966 Fender Pro Reverb
DC-3 head
Orange Dual Terror
J.J
Post by J.J » Sat Jun 25, 2011 5:54 am
The Tung sol is a great tube and has been my favorite new tube for a few years now. It almost always has taken my amps to where I want them tone wise.
One thing though, more than one or two may be hard on your ears as they will tend to shift your tone to the bright side.
What I would do is find which tube is bad by substituting one of your new tubes into each slot. Then change your tubes around so that you have a Tungsol in V1 or whatever the first gain stage is and the stock tubes every where else.
Have a good play and decide if you like that and then perhaps target V2 and see if that was an improvement or not.
Triple Crown 50 combo
Express 5:25 1x12 combo
JCM800 2203
Deluxe reverb reissue
gibby58
Post by gibby58 » Sat Jun 25, 2011 10:57 am
J.J wrote:The Tung sol is a great tube and has been my favorite new tube for a few years now. It almost always has taken my amps to where I want them tone wise.
Thank you, I get it now. I'll start with V1. Thanks again.
J.J
Post by J.J » Sun Jun 26, 2011 8:44 am
Let us know how you go.
JCM800 2203
mule#1
Post by mule#1 » Fri Jul 01, 2011 3:49 am
The pencil eraser trick works like a charm!
MK V Head
MK V Quilted Bubinga Combo
Marshall 410H
Marshall 410HJS
Mesa 2X12 Metal Grill Cabs
Standard 4x12 (Slant) & 2x12 (Horiz)
Traditional 4x12 (straight)
Gibson Les Paul's,SG, Explorer, Firebird, ES-339
http://www.paradoxxroxx.net
