How do you know if a rectifier tube is bad.
Since their purpose is to convert power, would it not be correct in assuming that if one is bad that the amp would blow a fuse or not function?
Would one then switch to silicon diode? Would the amp work if silicon diode was selected with bad rectifier tubes?
How do you know your power tubes are bad?
Would the sound level be effected?
Please let me know your experiences, thanks.
