First of all, say hello to everyone since it's been a long since i read the forum, but it's the first time i decide to register and participate.
Second, i must apologize for my english, i'm spanish and i still have a lot of work to improve my english. I understand better than i write or speak.
All this said, here i go.
I've already used the search engine and have not seen anything clear enough about this.
I've been using tube amps for years, and a couple of years ago i went for my first mesa. A triple recto.(not bad )
It's time to change tubes now, and as i've been a Eurotubes customer for some time i decided to contact Bob so he could recommend eme some tubes to improve a bit my sound. I'm going for the KT66 in the power section, but not a sextet but a quad so i'll pull out a couple of tubes. Which ones do you recommend? I've read it doesn't matter, but i prefer to confirm. And also to confirm if i can pull the rectifier tube i want, no matter wich one.
Would this affect if i use diodes or tube rectification?
And for the preamp i'm going for the ECC83S gold pin (i know many of you would recommend me another configuration instead of a whole JJ preamp, but at this moment i want to try this config, since it's the first time i'm retubing my triple recto). Do you think i should use all of them balanced , matched or both of them?
And well, the most important question, since its relative to the impedance.
Bob told me this:
Is this correct? I don't get the point of having double the impedance of the amp in the cabinet...
Thanks a lot for your help! I'll try to help from now on with whatever i can.
Bob told me this:
Bob said:You can pull either the outside two tubes or the inside two tubes in a 100 watt amp and then set the impedance on the amp to one half the value of the cab. Example, using a 16 ohm cab set the amp to 8 ohms.
