Post your rig - part 3
Post your Rigs and Sound clips for Mesa products
RustMaster
Re: Post your rig - part 3
Post by RustMaster » Thu Jul 27, 2017 5:59 am
I've been lurking here for years and never posted my rig.
1979 MKIIA HRG Head "BEEF SUPREME"
1986 MKIII Purple Stripe "The Nurple"
screamingdaisy
Post by screamingdaisy » Thu Jul 27, 2017 9:47 pm
Looks like it gets used. 8)
RustMaster
Post by RustMaster » Tue Aug 01, 2017 10:12 pm
I gig it some but believe it or not , I bought most of that stuff on the cheap in the condition that its in. With exception of the MKIII on the left. My uncles pet rabbit mangled the tolex on it and many other things around the jam room. I broke the pot on it loading out one night. The Lone Star Cab and the IIA are in the condition that I bought them in!!!!
screamingdaisy
Post by screamingdaisy » Sat Aug 05, 2017 8:06 pm
MarkPurney
Post by MarkPurney » Tue Sep 19, 2017 7:30 pm
Head: JP-2C Limited Edition #084/325
Cabinet: Vertical 2x12 Recto-Slant loaded with WGS Retro 30 and WGS ET65 mix
Effects Rack: Custom made by Casesmith Customs
MIDI Control: Digital Music Ground Control (old but good)
Effects Loop: TC Electronics G Major 2
Power Attenuator: Tonehunter SPL Reducer 200W
Guitars: Ibanez 7-string w/EMG 707s, Legator Ghost GHFN7 fanned fret coming soon
JP-2C Ltd Edition & 2x12 Vertical Recto Slant,
Selling: Mark IIb hardwood combo w/5-band, Studio .22 combo w/5-band
Maer
Post by Maer » Sat Apr 07, 2018 12:28 pm
Finally registered today.
Shure UR4D wireless + UR1 beltpacks
Fractal Audio Axe-FX 2
Roland JC120H
Mesa Boogie Lonestar 2x12
Diezel VH4
Mesa Boogie Rectifier 2x12
Voodoo lab GCP
Roland JC120H
Diezel VH4
Mesa Boogie 2x12 Rectifier Cab
Mesa Boogie 2x12 Lonestar Cab
Voodoo Lab GCP
Eevil
Post by Eevil » Sat Sep 29, 2018 11:58 am
ED + Stiletto 4x12 + Recto 2x12
Gears do rotate
Thaymz
Post by Thaymz » Mon Nov 12, 2018 3:11 am
Hi all
I recently added an original 2c+ to the arsenal and I am beyond words on how this all sounding. All running simultaneously and some sections in stereo. It's that good its a wonder I ever leave this room.... which sometimes I don't and if I do it's usually against my will.
I've put some detail in this thread with info on how to set it up with multiple heads using the axe fx (or any other midi unit that has multiple outputs) for anyone interested.
https://forum.grailtone.com/viewtopic.p ... 67#p519467
Now I just need to get a better desk that will fit it all :)
Noob_of_War
Post by Noob_of_War » Fri Dec 21, 2018 2:22 pm
Been Lurking, thought I would post up my Christmas gift from Santa...JPIIC with a factory DRG IIC+
TStone2
Post by TStone2 » Fri Apr 12, 2019 1:41 pm
Not sure how to crop this pic down a bit but here's the new setup. I've had the Stiletto and 4x12 since 2009.
New MV 90W purchased last month. I split out stereo from a TC Nova Delay. Just getting used to how to balance the 2
out. Clean settings are working out the best so far. The Mark 5 is a beast, been messing with it for the last 4 weeks. Awesome amp-
Mesa Stiletto Trident Stage 1 Head Est:2005-6 P:2009
EVH 5150 EL-34 2-12 Cab Est:2018 P:2019
Mesa Mark 5 90W Head Est:Mid 2018 P:2019
Mesa Recto 4 X 12 Cab V30's P:2009
Fender Combos. Fender and Ibanez Guitars
iliasantonakos
Post by iliasantonakos » Thu Jun 18, 2020 2:21 am
New G-system Mesa Mark V 25 rack set up..
G-system is in the loop of Mesa Mark V 25, so i have 3 cable method set up.
Mesa Mark V 25 head is rackmounted via aluminum cell from Forsburg company.
This cell lets you rack-mount the Mesa Mark V 25 head without modification or removing it from its wooden frame!
The whole thing is powered by Furman Pl-Plus E Series II conditioner.
Signal flow:
Guitar-->Isp guit in-->Isp guit out-->Nova Drive in-->Nova Drive out-->Mesa guit in-->Mesa effects loop send
-->Isp dec in-->Isp dec out-->G system insert return--> G-system L output-->Mesa effect loop return.
Also
G-system midi out-->Nova Drive midi in
G-system loop 1 button turns on/off distortion side of Nova Drive
G-system loop 2 button turns on/off overdrive side of Nova drive
and
G-system sw out 1-->Mesa ft sw
So, G-systems changes Mesa's channels via loop 3 button.
I also run a Boss FV-500H for volume purposes only..
The cabling is very short and the system stays completely silent even at extra high gain settings.
With this set up i bypass the front section of G-system so i can't take advantage of everything that sits there
such as the four analog loops and the filter/compressor section (compressor, wah, whammy etc.)
On the other hand, i don't have to worry about using TRS cables and special devices such as Morley Hum Eliminator,
Lehle Synday Driver etc..
If i want to go wireless i use Line 6 Relay G50.
For stereo set up i run a cable from G-system R output to another power amp/speaker..
I run the whole thing into either Mesa Boogie Thiele 112 or Recto 212 cabinets.
Sometimes i go into Two Notes Torpedo C.A.B. M (with mesa original impulse responses)
and then to mixing console for rehearsal or recording purposes.
Amimaster
Post by Amimaster » Sat Jul 09, 2022 11:48 am
So, I never posted it anywhere, but this is my Quad Preamp + Strategy 500 rack. Effects and boost pedals are provided by a Lexicon MPX G2. Everything on the back is meticolously wired using neutrik jacks and orchestrated by a rockman octopus.
The 500 pushes a pair of vertical 2x12 Seventy70 neodymium speakers (custom made by Luca Fanti, an Italian maker) in stereo configuration. While they may don't provide the most classical mesa sound, they IMO still sound amazing as they are very punchy and tight where needed. Also in my digital rigs I always end up using the IR I extracted from them, an couldn't get away without it.
I built this rig in 2006-7 when I was just a young Hammett fanboy. Then I stopped doing concerts and moved to an apartment, so I keep it stored as a relic while waiting for its moment to come again.. I would have completed it with a Masotti MXM parallel mixer and possibly a decent rack power supply. I'll try to provide samples as soon as I have the occasion to play again with it...
I'm aware it has way too much power (and weight) then I could possibly need, but when you're young you often overdo things, don't you? :). However I'm very proud of this rig and it's my most precious belonging, along with my guitars.
To fit my current needs (and building mania) I'm trying to build a mesa inspired amp in a head+cab format that I could bring to practice sessions without needing for a truck... I'll keep you updated about that :lol:
Markedman
Post by Markedman » Tue Jul 26, 2022 1:43 am
Image9/13/2021 by John Bazzano, on Flickr
