YellowJacket
I was having a discussion with 94Tremoverb via PMs about dual purpose rigs and it was getting interesting so I thought we could move the discussion here.
Short version:
Guitar amps CAN be used as bass amps. It is guitar SPEAKERS that are vulnerable to bass frequencies and will get blown easily.
1) Contrary to internet wisdom, an actual certified tech says that the components on a guitar amp ARE tough enough to work with a bass guitar. IN fact, the output transformer is stressed HARDER running high gain guitar distortion than it is running bass. You WON'T BLOW the components on the amp with a bass.
2) I phoned Mesa Boogie and they said plugging a bass into my Dual Rectifier would not harm it.
3) Run 6550 power tubes and a 12AT7 for a phase inverter so maximize headroom and minimize distortion
4) Use high efficiency speakers. A 100watt amp running 103db / watt / metre speakers is at LEAST as loud as a 300watt amp running 97db/ watt / metre speakers. More wattage simply increases clean headroom.
5) USE ENOUGH SPEAKERS! A 210 doesn't move enough air for bass. Run at least a 210 with a 115 or preferably a 410 with a 115 or 215 etc.
Short version:
[/quote]It's nonsense that you need more robust parts for bass - if anything, cranking a guitar amp flat-out into power stage distortion is far more stressful for it than clean bass. Back in the old days, Marshall built Super Lead and Super Bass amps (and PA amps) with exactly the same parts apart from a few preamp values, and the bass ones hold up just fine - the only difference is in the frequency response. It's the speakers that tend to blow if you use a guitar amp for bass, not the amp.
They recommended I get a bass cab for my head so I went and shopped for one. The $220 I paid for the 210 (used) was as much money as it would have cost me to replace the g12m heritage in my 2 x 12. I'm glad I did, I have the most beefy practice rig EVER! (we aren't even going to discuss bass amp options in that price range)
I know the 2x10s can be loud (esp. with neodymium speakers) but they just don't seem to fill a space like the big cabs do, in my experience... I've never heard one that can really cut it for a gig unless the amp is going through the PA too. 4x10"s are much louder - doesn't really matter if it's one cab or two, in fact an Ampeg 8x10" is actually four sealed 2x10"s in the same outer box!
