emperor_black
The cab I tried was listed for $469 at guitar showcase. I plugged in a Gibson SG with SD's first and then an Epiphone with EMG's. I tried the 'burn' setting of a Express 5:50 set at 5 watts. I play mostly metal and felt that amp did not have enough gain for my taste (no surprise there!). I cranked the bass and yet the cab felt lifeless and thin. I then plugged in a Mesa single rectifier recto-verb. I turned to its Channel 2 'Modern' sound. Bass & gain was reduced/cranked, mids increased/scooped, presence around 12 o'clock and yet the cab seemed lifeless. Did not like it at all. The cab has the stock Celestion 90 whatever speaker in it. I must confess I did not turn it up very loud, but I could hear everything I was playing clearly and assume that's good enough to test a cab.
My reference: I have a Mark IV, running a Jackson Dinky with passive SD humbuckers. My cab is a epiphone valve junior cab which had a ported back. I closed it shut, unloaded the stock eminence lady luck speaker and replaced it with a celestion v30. Comparing this cab's sound to the Thiele makes me glad I did not pay $350 for the Thiele on a recent eBay auction. My cab has a tight bass gets very loud for its size and has all the clarity, presence, etc.
Are the widebody thiele's comparable to the regular thiele's? Or is the speaker at fault?
