Mark v 35 & OD pedal on channel 1?
Guitar and bass FX discussion
MartinBoogie
Post by MartinBoogie » Sun Jan 28, 2018 3:08 am
Hi there, someone told me i shouldn’t place an overdrive pedal on channel 1 of my new Mark v 35 head, now, is this because it would damage the head or just because of personal taste? i would like to add my 45 bullet by J Rockett, as i did for a test, i got some real cool vintage sounds, while using channel 2 for a more modern distortion sound, what do you guys think? thanks.
Mark v 35 head
Mesa Boogie 1x12 Cab.
darkbluemurder
Re: Mark v 35 & OD pedal on channel 1?
Post by darkbluemurder » Mon Jan 29, 2018 4:30 am
That can only be for personal taste. The likelihood of damaging the amp is very low. As a general rule I would not use pedals with very high gain into a distorted amp channel - it could be too much and muddy. However, distorted amp channels benefit from overdrive pedals that have a bass attentuation (e.g. tube screamers, RATs, treble boosters) as they filter out or lessen the frequencies which cause mud.
On a clean(er) channel you can use anything you like - light drive, medium drive, high gain distortion whatever. There is nothing wrong with the use that you suggested.
Cheers Stephan
MartinBoogie
Post by MartinBoogie » Mon Jan 29, 2018 10:34 am
Thanks dark blue, just what i though, only want it to double check with other Boogie users, and yes , basically i want to add an overdrive only to channel one at times, not channel 2, that channel rocks on its own, than again.
