Help-signal pop and delay effects in and out of effects loop
Guitar and bass FX discussion
Boog
Post by Boog » Mon Sep 07, 2015 2:39 pm
Hi all, new owner of Mark V-25 and 2x12 rectified vertical slant cab.
I'm having signal pop issues with my maxon tube screamer each time I stomp.
And
I stack a maxon analog delay with a TC Elec. flashback delay. On all three channels they sound good but when i switch to any of the channels on channel 2 the delay gets wonky and super robotized.
Any tips or tricks for remedy?
Thanks
elvis
Re: Help-signal pop and delay effects in and out of effects
Post by elvis » Fri Sep 11, 2015 12:44 pm
You may be overdriving the inputs of the loop effects. Most pedal effects are designed for instrument level, and the FX send of amps, Mesa in particular, are a lot higher. I had that issue with the V:25 even with a TC rack box that was designed for line level.
The master controls the FX loop send level, so try turning that down. I couldn't run it more than about 11:00 with the TC box in the loop. If you need to make up the gain after the effects boxes, try adding a preamp like a micro amp or EH Booster, or use an Ebtech Line-Level Shifter to drop the level into the FX boxes and then raise it back up for the FX Return. The Line Level Shifter is a transformer, so it will also stop ground loop hum.
Mini Rectifier blue LED
Stiletto ACE
F50 Combo
Recto 2x12 Vertical
Recto 2x12 Wedge
