Midi Controlled Volume
Guitar and bass FX discussion
r33per
Post by r33per » Thu Aug 27, 2015 7:47 am
So, MIDI fanatics!
This is probably a topic that has been posted a thousand times, but I'd like to control my volume *in the effects loop* of my Triaxis via MIDI. Now, I don't want my expression pedal (on an ART X-15...) to control the TA's master volume, nor do I want it to control the output volume parameter on my TC D-Two. This is because as I change presets the volume level (if I can call it that) changes i.e. if I have the expression pedal half-cocked, that setting does not travel from one preset to the next. Think of it like I want it to act like it is going through a volume pedal without actually having my signal leave the rack.
Therefore, I was thinking about something like the Prostage Remote Volume (http://www.prostage.eu/midi-volume-pedal.html) device. Do any of you have experience with this or any similar kind of product? Obviously if I need corrected about effects-loop volume control in some way, please let me know - every day's a school day...
Stu
True North Function Band
Ibanez JS10th
Ibanez RG752AHM NGD
Mesa Triaxis (V2, TX4D)
Mesa Simul-class 2:90 (V1)
TC G Major 2
TC 1128
Marshall 1912
elvis
Re: Midi Controlled Volume
Post by elvis » Thu Aug 27, 2015 8:39 am
I'm using a Dunlop rack wah/volume. I've run the volume both in front and in the loop and haven't needed to mess with anything. It just worked.
Mini Rectifier blue LED
Stiletto ACE
F50 Combo
Recto 2x12 Vertical
Recto 2x12 Wedge
domct203
Post by domct203 » Mon Nov 02, 2015 10:36 am
With my TC G-Major I can set an internal parameter so the global volume stays where I set it with the expression pedal as I change presets.
Check your D-Two's manual to see if that also applies with that unit.
Dom
'07 Roadster Voodoo modded
'08 Stiletto Deuce II
'10 Mark V - sold
'18 TC-100
'01 Recto 4X12 Slant
'04 Recto 4X12 Slant/Straight
'74 Les Paul Custom
'95 American Strat
'12 Les Paul Signature T
Voodoo Labs MIDI
==> NOMAD on Facebook <==
r33per
Post by r33per » Wed Nov 04, 2015 7:40 am
domct203 wrote:With my TC G-Major I can set an internal parameter so the global volume stays where I set it with the expression pedal as I change presets.
Good call... I'll take a peak... Thanks :)
Ibanez JS10th
Ibanez RG752AHM NGD
TC G Major 2
TC 1128
Marshall 1912
