TERRIBLE hum from the effects loop and sub par tone
Guitar and bass FX discussion
Alucardtes
Post by Alucardtes » Tue Jul 21, 2015 7:35 am
Any suggestions on how to eliminate the hum that I get from the effects loop? Noise suppression pedals don't work for me btw. Also my distortion isn't as "good" as some people I hear demonstrating the head online. Early 2000's Triple Rectifier btw.
elvis
Re: TERRIBLE hum from the effects loop and sub par tone
Post by elvis » Tue Jul 21, 2015 1:36 pm
Ground loops. Power the pedals from batteries or get an isolated power supply for them (like Voodoo Labs Pedal Power). Even then, you may need an isolation transformer or two.
You may need a buffer as well. The FX send output impedance on many tube amps is quite high, so you get a signal loss and tone loss going into a low-impedance pedal or rack unit. Put a good buffer between FX Send and the first effect in the loop and this can help.
Mini Rectifier blue LED
Stiletto ACE
Recto 2x12 Vertical
Recto 2x12 Wedge
Alucardtes
Post by Alucardtes » Tue Jul 21, 2015 6:24 pm
I'll try the battery method first. Thanks \m/
afu
Post by afu » Wed Aug 26, 2015 9:13 am
Alucardtes wrote:Any suggestions on how to eliminate the hum that I get from the effects loop? Noise suppression pedals don't work for me btw. Also my distortion isn't as "good" as some people I hear demonstrating the head online. Early 2000's Triple Rectifier btw.
Can you explain your rig?
Are you powering pedals in front of the amp and in the loop with the same power supply? I get a ground loop hum from a One Spot if I use it in both places. An isolated power supply is the answer, or use batteries for one location or the other, if this applies. The pedals that normally go into the front are better on batteries, since distortion, overdrive, or compression require less current to operate.
My Humble Music Tech Blog:
Dual Rectifier Index
soundchaser59
Post by soundchaser59 » Tue Nov 24, 2015 7:14 pm
Carry it one step further.......don't power your amp and your fx loop pedals from the same power strip.....seperate strips and seperate power supplies. I got an above average power strip from Tripp Lite where each half of it is isolated from the other half, and I plug the amps in one side and the pedals in the other side. and my hum problems went away.
But yeah, Alu asked the right question.....what's your rig like? How do you know it's coming from the fx loop and pedals?
Rivera R55 and K55, Frenzel 5E3-40, MIA Strat, Reverend 6 Gun, Weber, Reaper.
afu
Post by afu » Sun Nov 29, 2015 9:43 am
The other thing is that and early 2000s Triple has a parallel loop. I always had problems with my Dual, so I modded to the loop to serial. Since I use a processor in the loop, I changed the way I use the FX Send to get a tone that's very similar to the loop in bypass.
screamingdaisy
Post by screamingdaisy » Sun Nov 29, 2015 12:42 pm
Alucardtes wrote: Also my distortion isn't as "good" as some people I hear demonstrating the head online. Early 2000's Triple Rectifier btw.
What guitar, pickups, cab and speakers are you using?
What amp setting are you using?
How loud can you turn it up? Rectos can sound good at low-ish volumes, but they don't start doing the Recto "thing" until you start going above about 10:30 on the volume knob.
