Tc flashback/mini flashback delay with mark v 25
trialandrews
Hey There ! I tried the flashback in the fx loop, and it looks like the input of the delay is overdriven...at low volumethe delay works pretty well, but as the volume goes up on the gain channel of the mini mark v, the delay effect disapear...any idea? Cheers!?
You may need to drop the FX signal level. This is common in Mesa. Either run the master lower or use an Ebtech LLS to give you a lower loop signal.
If you need to have more signal to the power amp than the delay will allow, turn the amp master down (this sets loop level) then add a boost pedal after the delay to boost the signal back up.
