Need effects info and suggestions
ESPJohn
Hi, I have a mesa dual recto and 4x12 recto cab. I need effects like loop, phaser, flanger, chorus, etc...
Should I buy the individual pedals or a "rackmount" unit for the effects?
I'm still new to how to use the amp/cab setup and how to use pedals with it.
I've googled about how to use the effects loop.
Is there an effects processor that can give me all of the effects i want, without having to buy many pedals,
And that will sound great with dual recto?
When i owned a pod hd500x I tried to use its effects but it sounded absolutely terrible. I connected it
using the 4 cable method and it cut the life out of my dual recto tube sound and i could only use the ~4 effects before the amp on the pod display, because when placed effects after the amp on the display the sound got much worse.
Thank you for any suggestions.
