Any looper reccomendations
Guitar and bass FX discussion
Theonlyway
Post by Theonlyway » Wed Dec 31, 2014 12:43 pm
I've never owned a loop pedal, and I've been researching a bit. Some I found seem to drop certain sound qualities when engaged. Can anyone recommend a quality loop pedal? Thanks in advance
Esp eclipse standard honeyburst, Mesa Roadster head, custom Omega enclosure
Strymon El Cap and Blue Sky, Maxon OD808, Marshall jackhammer, weeping demon wah
Looking to purchase a Lonestar 10,50,100 watt head.
MusicManJP6
Re: Any looper reccomendations
Post by MusicManJP6 » Wed Dec 31, 2014 1:52 pm
Like a phrase looper or a true bypass looper to switch FX in/out?
Mark V:25 | Mini Rectifier 25 | Mini Rec 1x12 | Fractal Audio FX-8
'06 EBMM JP6 (Mystic Dream) | '15 Epi ES-339 PRO (Cherry) | '11 PRS SE245 (Tobacco Sunburst)
'05 PRS SE Soapbar II (Vintage Cherry) | '92 Peavey Predator USA (Custom)
elvis
Post by elvis » Wed Dec 31, 2014 3:00 pm
I use the Ditto and I love it.
Mini Rectifier blue LED
Recto 2x12 Vertical
Recto 2x12 Wedge
Theonlyway
Post by Theonlyway » Wed Dec 31, 2014 7:59 pm
MusicManJP6 wrote:Like a phrase looper or a true bypass looper to switch FX in/out?
phrase looper. Apologies.
dbagchee
Post by dbagchee » Tue Jan 13, 2015 4:24 pm
Yeah just picked up the Ditto - sounds great! It doesn't seem to affect your tone when engaged and the playback sounds very true to the original signal. I compared it to the Digitech Jamman (compact pedal) and it sounded noticeably better. Previously I was using a Line 6 DL4 for looping.
Mark Five: 25
Recto-Verb Twenty-Five 1x12 Combo
Stiletto Deuce (Stage I)
Check out my band Asyst!
elvis
Post by elvis » Wed Jan 14, 2015 1:58 pm
I have two of them (can't stop at just one...). It is tiny and sits unobtrusively on my board. Whenever I get a hankerin' for a loop, there it is. I use it a TON when practicing at home, or when writing.
Recto 2x12 Vertical
Recto 2x12 Wedge
Theonlyway
Post by Theonlyway » Wed Jan 14, 2015 5:32 pm
I appreciate the responses
Woodsgirl
Post by Woodsgirl » Wed Feb 18, 2015 2:40 pm
Ditto Looper by TC Electronic
Very simple and that's what I love about it.
MINI RECTO thru 1X12 MR cab
PRS CE24
FENDER TELECASTER
PRS SE SINGLECUT
MusicManJP6
Post by MusicManJP6 » Wed Feb 18, 2015 4:55 pm
Yea, the ditto rocks. I ended up with a Flashback x4 which has a great looper built-in. The ditto sounds a hair better if I recall, but the x4 comes close.
sanfender
Post by sanfender » Fri Mar 13, 2015 7:32 pm
I highly recommend the Ditto as well because (a) ultra compact and (b) super easy to use. In the past, I've had a Boss RC-3 Loop pedal and found the interface cumbersome. The Ditto is very clean and simple in its design. Plus, it's good enough for Paul Gilbert :)
Another way to do it is if you have a recording set up that makes it convenient to loop via DAW. Sometimes I do that depending on my workflow. Regardless, can't go wrong with the Ditto IMHO.
