'dual mode' pedal board; ideas?
rens
London
Hi-
Im wondering if anyone has a nice solution to the following issue:
I like using my pedalboard with the time based effects (delay, chorus, vibe, and looper) in the effects loop and with the gain and filter stuff in front.
however, I often find myself having to plug into back line at festivals etc. where I cant easily do a 'four cable' setup.
With a patch panel (normal) at home I've been able to set up my pedals so that by default the entire 'time' loop is appended to the 'gain' loop but if I patch an additional 2 cables in (amp effects send and return) it takes the time stuff out of the 'front'. But a 48 port patch bay is not something Im adding to
my pedal board!
Has anyone used a widget that is effective for this? If not, I might take a shot at making one. I think a very small form factor 4 port patch bay would do it. no external switched or anything would be needed.
I know I could just separate the board into two but I like to keep the board wired nice and tight both for quick setup and so that I don't get
cable continuity problems from stuff flexing.
ideas?
Rens
I'm putting together a board with a similar requirement for combining the pre/post FX into a "front of amp" pedal board. I've preordered a Temple Audio pedal board that will come with a patch bay on the side to route the cables to the amp FX loop so I plan on just using a short jumper cable on the patch bay to put it in "front of amp" mode.
http://templeboards.com/pages/modular-end-panels
You could wire this yourself if you are handy too. There are also patch boxes that will achieve the same type of thing:
http://www.loop-master.com/pedalboard-patchbay-p-155.html
