Buzzing from the effects loop
Draconova666
First off, I am using an older Triple Rectifier (early 2000's) on channel three I am running the following chain: Head - Digital Reverb - Digital Delay (both are part of a pedal board, but only they run into the loop). I tried putting my noise gate at the end but the buzz is still present. Any ideas on how to fix this?
Remove one pedal at a time from the chain. If the pedal(s) is not the problem, start replacing cables - send, patches to each pedal, return - one at a time.
