Issue with TC pedals in Rect-o-verb loop
Guitar and bass FX discussion
anders.blomberg
Post by anders.blomberg » Thu Feb 20, 2014 5:00 pm
So I've got this issue with my TC Electronic Hall of fame reverb and Nova repeater pedals in the loop of my Rect-O-Verb 50 mk II combo. What happens is basically that some sort of noise gets feedbacked in the pedals and it sounds horrifying. The problem occurs when I turn up the volume on the pedals. I've uploaded a video of the problem here https://www.youtube.com/watch?v=0wJp5bATdxc.
I've tried other pedals (tremolo and overdrive) in the loop and have no problem with them. I've tried the pedals before the amp and there's no problem there. I've tried the pedals in the loop of a Mesa in the local store and no problem there either. I've changed all cables without any success. I've changed the FX loop tube without noticing any difference. I can't even figure out if the problem is in the amp or the pedals. Please help!
elvis
Re: Issue with TC pedals in Rect-o-verb loop
Post by elvis » Fri Feb 21, 2014 1:56 pm
Sounds to me like you are overdriving the pedals. Mesa amps tend to run really hot signals in the loops because the master volume is PRE-loop, so the full signal to the power section runs through the loop. I generally have to attenuate the FX send and then add gain after pedals in the loop if I want full volume out of the amp. You can use a LLS or a buffer with gain for that.
Mini Rectifier blue LED
Recto 2x12 Vertical
Recto 2x12 Wedge
mandoismetal
Post by mandoismetal » Fri Feb 21, 2014 10:49 pm
It's probably because the amp has a parallel loop. Even when set to the maximum value (90%-100% depending on the amp) for wet signal, there is still a little dry signal bleed in the circuit. Because of this, there is a a millisecond(s) delay between signals and although almost imperceptible to the human ear, it is enough to cause phase issues. My RoV did the same thing when setting my delays too high. You can try to mod your loop to series. Good luck!
Ernie Ball Music Man JP13
Mesa Boogie Mark V Head
Mesa Boogie 2x12 Rectifier Horizontal
elvis
Post by elvis » Sat Feb 22, 2014 1:07 pm
I disagree. Having a parallel loop causes a comb filter, which sounds like a flanger effect. It wouldn't affect the delays, for sure.
Recto 2x12 Vertical
Recto 2x12 Wedge
mandoismetal
Post by mandoismetal » Sat Feb 22, 2014 1:13 pm
Elvis, not trying to argue with you, but I had the same amp and pedal combination and that happened to me. I took my amp to a local tech and the nodded the loop. That solved my problem. It happened with my chorus and delays. Reverb was not affected.
anders.blomberg
Post by anders.blomberg » Sun Feb 23, 2014 1:18 pm
Mandoismetal, did you get the same kind of feedback as I do? From what you describe with signals being out of phase, I do not understand why the signal goes into this digital feedback-like noise? Also, since I tried the pedals in the loop of a Dual Recto head in the shop without problem, I'm thinking it might be a problem with my amp. Doesn't all rectos feature the parallel loop? But I might just be wrong. I'm just not to fond of the idea of fiddling with the amps circuits to make it series.
mandoismetal
Post by mandoismetal » Sun Feb 23, 2014 1:25 pm
Yes. I had exactly the same problem you're having in the video. I know it happened with my flashback delay and my chorus. I never cranked my reverb that much so I don't know if it would've caused a problem too.
Some of the very first Rectos had series loop as well as the newer reborn models. You can try replacing the tube that buffers the loop to see if that helps, but I'm pretty sure it is a parallel loop design flaw.
I hope this info helps out a bit.
anders.blomberg
Post by anders.blomberg » Sun Feb 23, 2014 1:29 pm
Guess that's it then. I'll leave a report if I get down to modding the amp.
elvis
Post by elvis » Mon Feb 24, 2014 9:53 am
Mando, thanks for the consideration. But you're SUPPOSED to argue with me. :twisted:
By any chance did you have anything else done when getting your loop modded, like adding a buffer or lowering the send level? I've done loop mods on my own amps, and the tech could have gone a lot of different ways with it.
Recto 2x12 Vertical
Recto 2x12 Wedge
mandoismetal
Post by mandoismetal » Mon Feb 24, 2014 12:57 pm
Elvis, lol I'll keep that in mind for future forum trolling.
As far as the mod, nope. He just swapped a couple of leads from the loop mix pot and tied down another one. I got the schematic straight from Mesa.
KiwiJoe
Post by KiwiJoe » Tue Feb 25, 2014 2:23 pm
Patient: "Doc, it hurts when I do this."
Doc: "So, don't do that."
It sounded fine to me until he tried to crank the levels. Too much "send" from the amp going to the pedal for that much level from the pedal? I thought that's what level knobs are for.
My Soundcloud
Mini Rectifier, Epi Dot 335
Once I stopped chasing tone, it stopped running away.
anders.blomberg
Post by anders.blomberg » Tue Feb 25, 2014 3:01 pm
I disagree on that it was working fine until I cranked the level. I see the reverb as an effect rather than just a spice in the background. When I turned up the level to what I consider a usable level, things got nasty.
So I went for my soldering iron, whipped it around for a bit in the amp, and now the loop is series, and effects are working like a charm. No downside to this! Easy as pie. Although I don't understand why the parallell loop funked things up. Thanks though!
Here are picks before and after the mod:
mandoismetal
Post by mandoismetal » Tue Feb 25, 2014 9:53 pm
Very neat and tidy work! I'm glad you got everything working fine for you.
elvis
Post by elvis » Mon Mar 03, 2014 2:23 pm
I am really struggling to explain how this could have been the cause. Glad it worked for you, though!
Recto 2x12 Vertical
Recto 2x12 Wedge
anders.blomberg
Post by anders.blomberg » Mon Mar 03, 2014 3:42 pm
I agree with you. I've sent the question to Mesa, but am still awaiting reply. Guessing it's not coming. Anyway, I'm really happy with the serial loop. Turned out it wasn't just the TC's that disagreed with the parallell. I never understood the Sonic stomp until now, after the mod. Having always destroyed my tone, it now really enhances it. And for general tone degradation from having the full signal go though the loop, I haven't noticed anything.
