Effects loop problems on Mk1 re-issue
65dlxrev
Need some advice please regarding the FX loop on my Mk1 re-issue:
I have just tried to use my pedal board via the send and return loop on the back panel - the Boss DD2 delay and the T-Rex Tremster work fine.
However, when I kick in the Fulltone OCD - or the ProCo RAT, I get dreadful screaming and white noise. There is also a general hum when using the loop.
When I put the board through the front end input, I don't get the hum - but the effects are not so rich sounding.
The board works fine through the front end of my original old 65 Deluxe Reverb or my re-issue 59 Bassman......any ideas?
Thanks
Bob
Put gain/overdrive/fuzz pedals in the front, modulation/delay pedals in the loop.
