TS808/TS9 Tru Bypass mod link
Guitar and bass FX discussion
bendo
Post by bendo » Thu Oct 04, 2012 12:59 am
Not sure about you guys, but I love and use my TS a lot. But the stock switch sucks, and I did not realize how much it robbed the signal even with the pedal OFF.
I'm sharing it cause it took me 2 hours to find this article. Others charge 50.00 for this service, I did it on my own with the link below in about 45 minutes, and cannibalized an old pedal (MetalMuff) I don't use anymore for a Switch and LED. However the parts can be had for about 4.00.
Makes a noticeable improvement. Took the thinness out of it. Also quieted it up a little on the buzz. Pops a bit when switching, but I think that's due to the 3PDT switch I used as it is old, and the MM had the same pop. Maybe clean it a bit. Also switches much easier, and the Red LED can actually be seen when on. Will pick up some new switches in the AM to fix the MM and hopefully quiet the pop.
Thought I would post it up here for everyone else. Save y'all from my headache.
http://www.premierguitar.com/archive/mo ... r/0704.htm
BDR529
gonzo
Re: TS808/TS9 Tru Bypass mod link
Post by gonzo » Thu Oct 04, 2012 12:05 pm
i would find a used Barber DDSS, and just step up.
but i understand the desire to mod what you have....
elvis
Post by elvis » Thu Oct 04, 2012 3:52 pm
With true bypass you will often get a pop. It's not the switch. It's the input and output DC blocking capacitors. They can have different DC voltages depending on whether they are bypassed or not, and can pull a bunch of charge to rebias when switched.
Mini Rectifier blue LED
Recto 2x12 Vertical
Recto 2x12 Wedge
Freaky
Post by Freaky » Fri Jul 05, 2013 7:14 pm
"pop noise" is bothering the crap outta me with two brand new "true bypass" pedals. I've heard about a missing ground on the AMP input signal path or some such stuff. I desperately need to know how to make the nosie go away. It renders the pedals completely useless for live gigs. :(
PS: Joyo Dynamic Compressor and Joyo Digital Delay are the offenders, and my Stilletto Deuce Stage II is the plaintiff in this case. (BTW the pedals sound pretty darn good IMVHO)
r_cod_81
Post by r_cod_81 » Thu Jul 11, 2013 5:37 pm
Richard Codling, Edinburgh/Newcastle, UK
Guitars: Jackson, Charvel, Dean
Amp rack: Studio Preamp, Behringer PEQ2200, Marshall 8008, 2x12 cabinet
Pedal board: Wah, Tuner, MXR (Dist+, Flanger), E-H chorus, Boss Delay
www.facebook.com/LiveBurial
kdorsey
Post by kdorsey » Thu Jul 11, 2013 9:08 pm
Thanks for posting the info. It is a really simple mod, but I opted to get my Keeley modded TS-9 Tru-Bypass'ed from the beginning. There's virtually no pop. Best TubeScreamer I've ever worked with.
'89 Mk III Combo - green stripe
Simul w/ EL-34s | EQ | Rev | EV12L
(2) Boogie 2x12 Half-back Cabs
bendo
Post by bendo » Mon Aug 12, 2013 10:20 pm
The pop went away when I put a new switch in it. I also replaced the tone capacitors with 200V Orange Drops. Opened it up quite a bit.
Premier Guitar has taken down all of the Keely articles down. However, I made PDFs of the important ones prior, so if anyone wants them, PM me.
I am getting ready to try the 18V mod.
BDR529
