Multieffects for Mesa rack
Guitar and bass FX discussion
osafer
Post by osafer » Fri Jul 20, 2012 6:43 am
Hi all!
I'm building a rack with a Mesa Rec Preamp and a 2:Fifty.
I'm looking for a good quality multieffects around 700 euros.
I'm mostly using delays and pitch.
Would you have any suggestions from stuff you have used?
Cheers!
elvis
Re: Multieffects for Mesa rack
Post by elvis » Fri Jul 20, 2012 3:01 pm
TC Electronic G Major is used widely, and for a bit more the G System is very nice.
Mini Rectifier blue LED
Recto 2x12 Vertical
Recto 2x12 Wedge
Geiri
Post by Geiri » Fri Jul 20, 2012 4:53 pm
Boss gt 10. You'll get a multifx + footcontroller in one unit. I have used it with a mk4 and a mesa rectoverb combo with excellent results. Channel switching and the works. Plus you can use it via the 4 cm and set it up so that your drives come infront of the amp and your timebased effects, delay, reverbs pitch and such go in the loop.
Mesa ROV combo
Ibanez 1451 black
Ibanez 827 qm premium desert red
Boss gt 10
and it's cold in Iceland ; )
http://www.myspace.com/angist
osafer
Post by osafer » Sun Jul 22, 2012 10:15 am
Thanks for your answers guys.
elvis wrote:TC Electronic G Major is used widely, and for a bit more the G System is very nice.
How's the pitch shifting on the G Major? Can it handle chords and distortion?
Geiri wrote:Boss gt 10. You'll get a multifx + footcontroller in one unit. I have used it with a mk4 and a mesa rectoverb combo with excellent results. Channel switching and the works. Plus you can use it via the 4 cm and set it up so that your drives come infront of the amp and your timebased effects, delay, reverbs pitch and such go in the loop.
I have the GT-Pro, but I don't like it at all.. It seems quite fake.... Do you get decent pitch shifting with gt10?
Geiri
Post by Geiri » Sun Jul 22, 2012 12:52 pm
If you don't like the gt pro then stay away from the 10. It's basically the same engine. I have also used the tc gsystem and that is my second favorite after the boss unit. If you are into the tc stuff you'll love the G system.
For my ears the pitch shifting is good on the 10 but if you think the gt pro sounds fake it will probably translate to the 10 also.
Mesa ROV combo
Ibanez 1451 black
Boss gt 10
elvis
Post by elvis » Sun Jul 22, 2012 10:36 pm
I have the G System. Pitch shift and harmonies are good, but not perfect. Definitely useable.
But a Multi-FX is generally designed for 'verb, delay and mod. If you want the best pitch effect, you will probably have to get a dedicated unit.
Recto 2x12 Vertical
Recto 2x12 Wedge
Triaxstasy
Post by Triaxstasy » Mon Jul 23, 2012 3:09 am
used Lexicon MPX-G2 with the R1 MIDI floorboard.....Delays and Verbs to die for, very convincing Wahs and ODs, lush Modulation FX and a decent Harmonizer (if the guitar is in tune)....
