Hi,
I recently bought a 3 channel Dual Rectifier, and I'm looking to buy an audio controller so I can switch channels + FX on my pedalboard. I'm looking at maybe buying the Musicomlab EFX Mk3+ because of it small size, as it needs to fit on my Pedaltrain2 pedal board.
Now, I would like to know if I can use a 7pin to 5pin midi cable to go from the amp footswitch out (7 pin) into the midi in (5 pin) on the musicomlab EFX? I don't want to use the external switching on my head as that would mean that I would have to run 5 cables from the amp to the pedalboard instead of 1.
The goal of this would be to be able to use the musicomlab to switch to channel1, disable the maxon OD and enable the chorus/delay, etc.
