MKIVb with MXR Noise Clamp in loop question.
Guitar and bass FX discussion
buzzlane
Post by buzzlane » Wed Oct 19, 2011 12:51 pm
Just picked up a Noise Clamp and not quite sure how to hook it up, or if I can hook this up the way I would like. The manual doesn't address my "plan". The noise clamp has send/return jacks, and in/out jacks. Basically I would like to use the MKIV's effect loop in the Noise Clamp's send/return jacks for my compressor and delays, and also use the Clamp's guitar in/out to gate my wah/od that goes to MKIV's input. Hopefully my description of this makes sense. I know the MXR Noise Clamp is kinda' new, but was curious if anyone has tried one in the amp's loop and direct input jacks, and if so, how it was connected.
Thanks for any help...
Rampage
Re: MKIVb with MXR Noise Clamp in loop question.
Post by Rampage » Wed Oct 19, 2011 1:40 pm
With the Noise Clamp, you just run a simple setup:
Guitar -> Noise Clamp Input -> Amplifier's Input (via the Noise Clamp's Output)
You then have the option of doing the following:
Noise Clamp Send -> Wah -> Overdrive -> Noise Clamp Return
I do not believe you can do the four cable method with the Noise Clamp. That said, running a gate in front will kill a lot of the excess noise you experience with a high gain amplifier. Whenever I was running a boosted 6505, a Decimator right after the guitar in my signal chain was enough for tight starts/stops.
G&L Rampage / Charvel San Dimas
Mesa Boogie MKIV Hardwood/Wicker 1x12
T.C. Electronic / Bodenhamer / Monsterpiece / Morley
Positive Transactions
buzzlane
Post by buzzlane » Wed Oct 19, 2011 2:00 pm
Rampage wrote:With the Noise Clamp, you just run a simple setup:
Thanks, I'll try that when I get home. Maybe I won't need to put my Pigtronix compressor and delays in the Noise Clamp's loop? They're not excessively noisey anyway....we'll see.....
Rampage
Post by Rampage » Wed Oct 19, 2011 2:20 pm
Compressors and Delays aren't typically noisy pedals in my experience. You can always try it in the loop, but I have always had good experience from simply running one out front. Plus it's that much simpler to set up for gigs and practice.
topcat0399
Post by topcat0399 » Wed Oct 19, 2011 6:46 pm
Why is your Mark IV so noisy?????
Mine is dead quiet. No need for a gate.
Me -------> 1973 Gibson Les Paul Standard------->1991 Mesa Boogie Mark IVa/b Combo -------> World.
buzzlane
Post by buzzlane » Thu Oct 20, 2011 12:54 pm
topcat0399 wrote:Why is your Mark IV so noisy?????
It's only noisy in the mid/high gain settings......Alot of hiss/hum, no feedback though. Rhy 1 is very quiet. Just picked up this MKIVb shorthead a month ago. It's a 2002 and is in immaculate condition. Virtually new....the guy I bought if from never used it. He estimated maybe 2 hours of use, so really can't be the tubes. Could the filter caps dry out from non-use? You would think I'd hear something on the clean settings too, if that was the case? Might just be my settings. I like a sustainy/smooth lead tone, so maybe that just goes with the territory? I only use OD pedal on the clean channel, and a boost pedal on all channels at different times. Have Pigtronix compressor and a couple delays in the loop. Comp adds a bit of noise, but it's not the culprit. Maybe just need to play with it some more.......?
topcat0399
Post by topcat0399 » Thu Oct 20, 2011 5:16 pm
Hmmm, not sure. I stopped using all off amp processing 10 years ago so I don't have that in the mix to deal with.
I don't have any hum and only get alot of hiss when the OUTPUT is run really really high. Most of the time my OUTPUT around "1" - maybe a little more (rarely). More than enough for most gigs in the clubs that we play.
How high do you run your output knob?
Ever try moving your preamp tubes around to see if theres a change?
Got a crappy signal cord somewhere?
It takes awhile to get to know a Mark IV - I hated mine at first.
You need to mess with it ALOT until you learn its character. Its worth it.
buzzlane
Post by buzzlane » Thu Oct 20, 2011 6:05 pm
You need to mess with it ALOT until you learn its character. Its worth it.[/quote]
Wow, only 1? I've only played out once with it so far and I was at 5-6 on tweed/triode/simul/harmonics. Not that I'm full on very often, only for leads on the rock stuff. I use a vol. pedal too. Guess our stage volume is a bit hot :shock: I'm loving the MKIV already, just need to mess with it more, and even now I'm pretty sure I can safely say it's the best amp I've ever had. Came from a rack/midi rig, and just got tired of the whole mess of stuff ya' know. I forgot the beauty of a great amp all those years. The feel, tone, juicyness of the high gain modes....like I said....I'm loving it! Actually inspired again...!!!
I need to go thru my chain and add each pedal one at a time and see if it's something like a bad cable, or connection.
quote="topcat0399"]
r_cod_81
Post by r_cod_81 » Fri Nov 04, 2011 9:07 am
I use a Boss NS-2 with my Studio preamp using a 4-cable hookup:
Guitar -> Noise gate input
Noise gate 'Send' -> Tuner -> Wah -> Amp Input -> FX Out -> Pedals in loop (chorus, flanger etc. -> Noise Gate 'Return'
Noise gate 'Out'-> Amp FX return
This works fine for me!
Richard Codling, Edinburgh/Newcastle, UK
Guitars: Jackson, Charvel, Dean
Amp rack: Studio Preamp, Behringer PEQ2200, Marshall 8008, 2x12 cabinet
Pedal board: Wah, Tuner, MXR (Dist+, Flanger), E-H chorus, Boss Delay
www.facebook.com/LiveBurial
buzzlane
Post by buzzlane » Mon Nov 07, 2011 5:03 pm
r_cod_81 wrote:I use a Boss NS-2 with my Studio preamp using a 4-cable hookup:
Tried your hookup with the Noise Clamp and it doesn't work. Must not be quite the same type of unit. Just got hum with no signal at all. It was worth a shot though.
r_cod_81
Post by r_cod_81 » Wed Nov 09, 2011 7:20 am
Hmm, maybe a different set of connection requirements. I'd try just the noise clamp and MkIV head without the effects so thatyou can make sure the connections work (ie get a signal) then add all your other effects. Check the noise clamp's instructions too to see what should be connected to what.
buzzlane
Post by buzzlane » Wed Nov 09, 2011 10:55 am
r_cod_81 wrote:Hmm, maybe a different set of connection requirements. I'd try just the noise clamp and MkIV head without the effects so thatyou can make sure the connections work (ie get a signal) then add all your other effects. Check the noise clamp's instructions too to see what should be connected to what.
It works if I hook it up as is stated in the instructions, but I can't get the effects in the MKIV's loop into the Noise Clamp. This is how I'm running it.
PRS >Noise Clamp input
Noise Clamp output > MKIV input
Noise Clamp send > Wah > Boss OD1 > Plexitone
Plexitone out > Noise Clamp Return
This works great for the OD/dist pedals. Completely quiets them. I only use them on the clean channel. Would be nice to get the effects (compressor,couple delays) in the NC too, but I guess I misunderstood the capabilities of the send/return on the NC. Most of the noise is the Pigtronix comp, which in my experience is typical of compressors...the delays are very quiet. I'll just live with it. In a live situation it's something I probably only hear... :?
r_cod_81
Post by r_cod_81 » Mon Mar 26, 2012 11:12 am
Hey there, sonly just noticed I haven't replied to this! Sorry for the months of delay...
buzzlane wrote:PRS >Noise Clamp input
That works fine for all your effects in front of the amp but will not include those in the MkIV's loop (and any noise the MkIV may produce).
Try this:
Guitar -> Wah -> Noise clamp input.
Noise clamp Send -> OD1 -> Plextone -> MkIV input
MKIV FX loop Send -> any effects in the loop -> Noise Clamp Return
Noise clamp output -> MkIV FX return.
That should work. If you don't want any reverbs/ delays etc to be noise clamped (you can lose the ends of delay repeats) then stick them between the Nose Clamp output and the amp's FX return.
Also yeah; a compressor does add noise as you add compression, try and keep it aslow as you can get away with.
Hope that helps, sorry again I took ages to reply!
