Space question?
Guitar and bass FX discussion
sekot
Space question?
Post by sekot » Fri Mar 04, 2011 10:55 am
I was just wondering how much height is there on a 2 space shelf, i'm looking to get a rack so i can keep my hotplates and other future things in it and wasn't sure if a 2space shelf would be enough room since they've got to have a good air flow.
screamingdaisy
Re: Space question?
Post by screamingdaisy » Fri Mar 04, 2011 11:03 am
Each space is 1.5 inches. How much space is taken up by the shelf depends on the design.
If I remember correctly, 2 spaces are enough if you remove the feet and bolt it directly to the shelf.
sekot
Re: Space question?
Post by sekot » Fri Mar 04, 2011 11:13 am
cool thanks, i didn't want them getting to hot in there
MrMarkIII
Re: Space question?
Post by MrMarkIII » Fri Mar 04, 2011 9:01 pm
One rack space (1U) = 1.75 inches/44.45 mm.
94Tremoverb
Re: Space question?
Post by 94Tremoverb » Mon Mar 07, 2011 4:31 am
You must not take the feet off the Hotplate and bolt it to the shelf! Because the cooling fan inlet is on the underneath. Or at least, if you do then you must also cut a matching vent in the shelf, and make sure there's nothing blocking it (like the rack enclosure or the next unit down) underneath that. Leave the feet and use longer screws that go through them and into the holes in the Hotplate, or maybe if necessary use different height feet, so it's equally spaced top and bottom... which would look better too :).
sekot
Re: Space question?
Post by sekot » Fri Oct 04, 2013 11:33 am
thank you. been away from the forum for a while. check it out often just never get around to posting
