Speaker out of phase dumb question?
Guitar and bass FX discussion
Pillsbury Dough Boy
Post by Pillsbury Dough Boy » Fri Apr 02, 2021 8:53 am
Hiya Folks
Can anyone answer this real real dumb question. I am using two mesa combos for a wet dry set up and I have a amp splitter box with a ground lift function but it has no speaker phase switching function. Now, currently both combo speakers are pushing out and in phase when played. My question is, will the phasing alter depending on the gig, or power supply depending on each gig venue or am I safe to use both in the confidence that the speakers will function correctly.
Can anyone answer this with certainty.
Thanks in advance,
PDB
CoG
Re: Speaker out of phase dumb question?
Post by CoG » Sat Apr 03, 2021 1:22 pm
You shouldn't have phasing issues at the speakers. You may still end up having audible phasing effects in a venue just because of how stage/room/rig are laid out. Put your combos side by side, like an inch apart, and if possible close mic them both and get your room volume from the PA instead of the amps.
Dual Rectifier Tremoverb 100 Head
MkIII Green Stripe DRG
Royal Atlantic RA-100 Head
Lots of Mesa cabs
Also owned: Rec Pre, 20/20, Bottle Rocket, a bunch of Mark IIIs, a bunch of Rectos, a bunch of other amps
