Parallel compression pedal suggestions?
Guitar and bass FX discussion
thinskin57
Post by thinskin57 » Sat Jul 21, 2018 4:19 pm
Can anyone suggest a good parallel compression pedal that would allow me to dial out the "pop" of the note attack that you hear on so many compressor pedals? I recently got the new Keely Compressor Plus and although it's parallel, the lowest setting on the mix knob is 50/50, wet/dry. I have NO idea why Keely did it this way. As such, i cannot dial out the "pop". I'm considering the Barber Tone Press but am looking for someone to confirm that the pop can truly be dialed out w/the mix knob before i purchase. If there are other pedals that can do this, i'm listening to your suggestions. I want a pedal that can give me lots of sustain, without the "pop". i aslo don't want to go over $200. a pedal with an attack knob AND a blend knob (like the Cali76) would be perfect, but would likely blow my budget. i'd also like it to have a footprint no larger than a tube screamer or the like.
