tavman said:
Only recording that I have done is through a J-Station with my computer.
Would like to get a good basic setup that is a little more robust. ie microphones etc...
Can anyone suggest a good basic setup to go for?
4 track recorder? cd vs tape vs digital setup?
Thanks :!:
I too use old Cakewalk 9 with an Echo Gina 20 bit DAC. Still works great. I also have a J-Station I use very infrequently, but I like its S/PDIF that connects directly to my Echo Gina.
Instead of mics, I'd recommend you go the tube preamp route, with built in speaker emulation. I have a Boogie Formula Preamp in a rack with an external effects and compression unit. The TUBE BUFFERED effects loop of the Boogie works great with digital equipment.
Boogie makes the Recording Recto preamp and the Triaxis, the Formula is no longer made. $1100 Recto, $1400 Triaxis new. VHT has a fine looking preamp that sells new for $1100. ENGL has a killer preamp for $2200.
Tube preamps can be had cheap on ebay. $400 to $500 buys a mint Boogie Formula. $850 buys a Boogie Triaxis. I've also seen great deals on ENGL 530s for $200, Soldano X-77s for under $300 etc etc. The KEY is finding a preamp with good built in speaker emulation for recording!!!!
I kind of like these new USB2 based external recording units. M-Audio has several models. Same with TEAC and several others. I like the idea of the A/D process taking place outside the computer's innards.
