Markedman wrote:
Is there a through output on the talk box? You should be able to connect the talk box to the speaker out from your amp to the talk box in and then from the talk box out to the speaker using only one 8 ohm output. Obviously you'll need two speaker cables, a guitar cable will not work between speaker out and the talk box in.
+1
The ones I've seen have 2 jacks, In from amp and out to speaker. So the footswitch on the unit is basically an A/B box meaning "A" would be talkbox engaged, speaker off or "B" speaker engaged, talkbox off . Is your concern an ohms mismatch?( the heil is 8 ohms ) Is your speaker cab 8 ohms? I'm unsure how you would run it with 2 outputs from your amp, you only want one or the other engaged at a time . An alternative you can A/B your guitar into 2 different amps, one running speaker, one running talkbox but that requires 2 amps. The only advantage there that I see is you can set the amp running the talkbox at different settings.
