Practice amp with effects loop?
lectar
Howdy all, just looking for some suggestions for a low wattage solid state practice amp with fx loop for bedroom volume, need the loop to run my ditto looper through! Cheers.
New: Tech 21 Trademark 30
Used: Tech 21 Trademark 10 or 30
They are expensive new because they are really good amps. On the used market expect to pay $150 - $180 shipped.
Exactly what I was going to say except that you can often find them even cheaper. They're good amps with good customer support.
The Yamaha THR10 is the ultimate practice amp for me. It sounds amazing and it has all the features you need and none that you don't. It's also a bit pricey, but I think it's worth the money.
It doesn't have an FX loop, but you could probably use the Aux input with the looper somehow.
