NEED HELP! Parallel Speaker Outputs!? Speaker wiring?! Huh?
Megawar
Hey guys!
In looking to get a EVH 5150 III 50 watt head. On the back off it, It's has 2 Parallel Speaker output jacks and a switch for 4, 8, and 16 ohms. Explain to me what is Parallel speaker output?!
Well actually, see if you can help me here first! I have a 2x12 cab with 2 WGS Veteran 30s speakers. 8. Ohms each, and wired in series for a total impendence of 16 ohms. Do all I have to do is plug 1 speaker cable into either left or right output jack on th EVH head into my 2x12 cab and flick the switc on the head to 16 ohm?
Megawar said:
Hey guys!
The answer is yes, switch the speaker output jack switch from the 5150 to 16 and plug your 16 cab into it. here's a quick illustration of parallel speaker wiring:
8ohms + 8ohms paralleled = 4ohms
8ohms + 8ohms series = 16ohms
8ohms + 8ohms +8ohms + 8ohms series + paralleled = 8ohms
