Vintage HiWatt re-bias , need help
Dmatrix
My friend got a HiWatt Custom 50 (model # DR504) from his dad. It had some problems in the past where it would keep burning through fuses so they put it away for a while. We replaced the tubes and fuses and got it to work, but after about 10 minutes of playing one of the EL34's plates would start glowing bright orange. If we kept playing any longer it would probably start glowing red...
We followed some instructions and soldered in a bias trim pot to adjust the bias back down to the factory value of -36V as per the schematic. But the one power tube still kept glowing orange after a few minutes of playing. I've tried swapping the tubes around, its not a problem with one of the tubes, only one side of the power amp is making the tube glow too hot.
Any ideas on what else I can do? Any more values to measure beside bias voltage?
Schematic we used: http://www.drtube.com/guitamp.htm#HiWatt (DR504)
If you have a trim pot then try going low and running the valve colder. It should fix the problem without causing it to go bang... check the operating voltage range and go to the lower limit and see how that works.
Good Luck, I love Hiwatts and hope yours lives on!
Andy
Check the grid resistors. Those may have drifted out of spec a long time ago. My mesa was doing something similar...
