It is currently Sat Jan 19, 2019 1:51 pm
 Post subject: Re: Guitar for beginners
PostPosted: Mon Feb 26, 2018 8:18 am
The PRS SE line seems to be pretty consistent good quality for the price or the more expensive Epiphone guitars are usually decent as well. Good luck
Current Amps:
Mark II C+ DG
JP-2C
Mark V:25
& Lots of Cabs!!!!! (all Boogie)
PostPosted: Tue Feb 27, 2018 4:07 am
The Yamaha PAC112J's are killer guitars for the money. I mean, astonishingly good. If you're wanting a great guitar for under $200, I can't recommend them enough.
https://www.youtube.com/user/BoyntonProAudio/videos <--- Fun Gear Demos
PostPosted: Thu Mar 15, 2018 9:39 am
You can get a Les Paul Special by Epiphone new for about $150. Great guitar for the value. You could find used Epiphones for about $100 as well.
If you wanted to up the price, you can find used Gibson SGs or LP Studios for under $500.
Ampeg 4x12 Cab
Gibson 2006 Les Paul Studio
PostPosted: Sat Mar 24, 2018 8:25 pm
I thought that this subject had been debated and the Made in Mexico (MIM) Fender Stratocaster was the overall winner. I've gigged a lot of $50.00 Squier Strats without a problem.
PostPosted: Thu Apr 05, 2018 6:26 am
Triple Recto
The Mexican made Fenders are good guitars. I have two friends who each have one. I also bought one but mine was a bit more expensive as it has a compound radius neck and Floyd Rose bridge. Dave Murray model. The build quality is very good although I wish there were 22 frets and the bridge was a full float vs being blocked by the body.
There are many good guitars for budget minded folks. I would spend some time and look at your local guitar shop, Sam Ash, Guitar Center or other. Sometimes you can find a great used guitar for about the same cost as a new low cost import. PRS,Schecter, LTD, ESP, Yamaha are also good instruments. Charvel and Jackson. I would look to find something you feel most comfortable holding in your hands first. Focus on the fret wire, the thicker and wider frets are always good to have (common on most MIM Fenders). If you can find one with stainless steel frets that is even better as bends will much easier than nickel alloy which tend to need buffing to improve the feel. Tuning machine heads are also important, some are cheesy and some are really good. I would also look at those, if it is a stamped metal (vintage looking machine tuner style) it may be difficult to replace if you need to do so. How the instrument sounds unplugged may be a good indication it will sound great plugged in. Try them out with and without an amp. Some will sound great and some will just be lame. It is really hit or miss when you get down to the lower cost instruments. Guitars with a fixed bridge may be a better option for a beginner since the tuning and string replacement will be much easier. Those with a locking tremolo bridge set up like a Floyd Rose will be more complicated to replace stings and take much longer to tune up and stretch the strings. (that aspect does not bother me and I actually love the Floyd Rose). Still for developing finger strength and technique the fixed bridge would be best. You can always get a different type of guitar later on once you get hooked.
PostPosted: Mon Jun 11, 2018 4:38 am
I dound a suitable guitar for me n start to practise for 1 month. Where can I find guitar club for beginner?
Just a smile and the rain is gone gmail sign up Life always open many ways for us. Find exist door!
