This appeared as part of another discussion. I wanted to take it to another level.
Questions to consider: is a rectifier capable of singing/sustaining leads at high level and what do you add or change to make this possible?
posting by: Blaklynx
Also, Recto amps aren't known for their ease of dialing in. They're not known to be great 'solo/lead' amps, either. Rhythm? No trouble. If you want singing, liquid sustain, these amps need help via a boost/OD pedal (TS9, 808 type pedals, other OD pedals) to push the front end.
That is interesting.
I am able to get an incredible lead/solo tone out of my two Tremoverbs...BUT it has to be at a certain volume.
If I am too low, it is thin or transparent.
If I am to high, it is lacking in exactly the characteristics that you spoke to in your post.
I don't think I ever read something like that before and give you credit for speaking up.
I never really had (until recently) a chance to "open" up my amps as everyone talks about.
I have NEVER liked High/Loud stage volumes, but unfortunately I never had Mesa products when I did play out live.
But, my practices with my band are "stage volume" which is to say we all compete or "Mix" to the level of the ambient drum kit level.
Having said that, I have two amps both running in stereo in a medium size, "dead" (acoustically) room, and they fill very nicely so I might be at 30-35% open.
It is a different story in the new rehearsal room, as it is three times the size and very "alive" (acoustically) I would say that I am about 50% open on my overall output in this new room.
Now here is my point, at this new volume I am understanding a little more what people mean when they say nothing sounds like a recto when it is running at high output, BUT at this volume I do LOSE the "singing, liquid sustain that I am accustom too.
Just one other observation, I use rectifier tubes/spongy settings. I have tried other settings using these controls/switches and have noticed more output and more gain, but not necessarily better tracking as others have mentioned. I am not really sure which I like better. If I choose silicon diode/bold, I have to reduce the channel masters and I don't like that, but I will continue to experiment and dial it in, which is another great bit of wisdom you share in your post...these amps are NOT easy to dial in and require patience and the will to succeed. I personally appreciate that attention to detail by Mesa
My question is, will something like the "Xotic" BB help for this problem?
Thanks all...
sorry for not getting the "quote" function to work when quoting Blaklynx
All settings are "Clockface" references.
Lower volume settings are: Channel Two, Modern, Gain @ max, Channel Master @ 7-8, Active Loop Master @ 9-11
Higher volume settings are: Channel Two, Modern, Gain @ max, Channel Master @ 8-9, Active Loop Master @ 12-2
It is important to note that tube and guitar options make a difference.
You may have high output pickups.
I did make a change to my PI tube that included swapping the 12AX7 or a 12AT7 JAN Philips.
This may not have much of an impact.
Also I swapped Mesa in the V1 position for a Tung-Sol 12AX7
I also use =C= EL34 for one amp and =C= 6L6 for the other.
V2-V5 are Mesa issue 12AX7.
The rest of my gear is listed below.
Please note that I experienced the same loss of sustain and singing notes before any changes were made.
Thanks all...
