Cheapshoes
- Joined
- Nov 18, 2009
- Messages
- 19
- Reaction score
- 0
Hello all; I'm new here and totally new to Mesa-Boogie amps. Very glad to see there is an active forum for these. I ran accross this very road-weathered Mark IIb (1980 on the chassis), and the amp has a few technical issues, but I saw it's potential as the tone is in there - just need to fix a few things. I'm asking for some kind help with technical advice. I took it in for repairs locally before doing anything, and although they fixed the reverb, they missed some huge things which is surprising. Volume 1 knob is still very sensitive (after about 6), but worse, there is a ugly crackling on certain chords and settings that is accompanied with a variable loss in fequency and volume that comes in-and-out rapidly while holding the chord. If this is as simple as bad resistors, or exhausted caps I'm game to order the parts and fix myself and save the hassle and money. Though - I think the tech thought the filter caps were still good. I haven't changed the 6L6s, but these are Sovtek WXTs, which should be built like a tank.
I'm not formally schooled in electrical tech, but understand the basic workings, have done several mods to other amps following guidance. So - what do you thinks this is? At first, I was thinking bad tube connections, but at least the 12AX7s seem tight. Also, curiously this uses 12AX7s in all preamp slots, no AT7 listed on the chassis for any slot. Appreciate any advice/simple diagnostic tests, suggestions what to fix. I also noticed the schematics on the web are all for the 100W +EQ version - mine is the 2x6L6, +reverb, no EQ version.
A lower priority are the cosmetics. The "cream" tolex is trashed and can be just peeled off, but leaves a greenish glue underneath. I think I saw on one of these posts just doing a heavy sand-job and varnishing the birch plywood as-is. That seems very appealing low -tech solution. If I want to put on new grill cloth - do those four screws in the front release the baffle so I can do that?
I know this is a lot Thanks!
