noghiri
- Joined
- Jan 23, 2015
- Messages
- 12
- Reaction score
- 0
I picked up a used Single Rectifier/Rect-O-Verb combo for 400$ a couple months back. It seems to be a somewhat odd duck.
After doing some research, I found there were two versions of the Single Rectifier line. Version 1 appears to have two settings on the distorted channel, and a smaller reverb unit, while the Version 2 has a Raw setting on the distorted channel, has a full reverb tank, the ability to switch between EL34 and 6L6 tubes, and a soloing volume boost.
My amp has two settings on the distorted channel (no raw), no ability to switch between power tube types, the full reverb tank, and the soloing volume boost. The back panel also matches that in the Rectoverb V1 manual. All spacing and lettering looks pretty much the same, no obvious differences.
Does anyone have an idea of what I have?
(pictures will follow, I need to drag this thing out of its spot over to where there's sufficient light for photo-taking)
