Mesa Boogie Mark 5 line out
Yes, you can use the slave out, connect it to a line input on the mixer. You don't need another box between unless you get a ground loop
I have a similar question. I want to connect the Mark V 90 to my recording interface (ua Volt), should I use the slave out and should I use a cab sim? Any help here is greatly appreciated.
Just to clarify, if I use the slave out to go to my recording interface does it need to be connected to a load box or can the slave out run directly into my UA Volt recording interface?
