afu
Southdakota said:In case anyone cares, I finally played live with the new Dominion bridge pickup and my Roadster. It is just as advertised....mid heavy but I feel more of a lower mid. I did put just a touch more high end in the eq but not much. Overall very happy with it. Nice big thick tone. Easier to pull off pinch harmonics. Seemed very responsive but definitely not a crazy high output.
That's good to know.
Since it was easier, I added another tone cap that makes the value 23.5 nf to get a stronger resonant peak at low tone control settings. By switching the pickups between parallel and serial wiring while using the selector switch, I can change the emphasis as I move up or down the neck. It's hard to describe, but it's kind of like switching from a baritone to 2 different tenors to an alto.
Another cool thing is being able to use Raw or Pushed for a crunch sound and swap to the Jazz pickup wired in parallel for an almost clean sound. It sucks on the clean channel, but works as an effect for smoothing dirty and filthy sounds. Modern doesn't really get clean, but it is less intense.
