davidp158
I'm getting early distortion in my LSC's channel 1 that I'd like to resolve. I'm trying to get a full, clear tone that won't break up at all (or very, very little) unless the solo switch is engaged. My LSC is an original version, 1x12 combo with an EV 12 speaker. I typically run both channels @ 100 watts, and use 6L6 power tubes.
I have to keep the channel 1 input gain below 9:30 to avoid harsh clipping, especially with humbucker pickups. The channel 2 midrange control adds significant distortion if set over 12:00. My channel 2 input and drive settings are usually around 11:30 -12:00. With these settings, my channel 1 master is often at 2:00 while my channel 2 master is around 9:00 to 9:30. Per settings I've seen the owner's manual, and settings posted here, my clean channel 1 master level seems to be out of wack with my channel 2.
BTW, I use a TC Electronic Nova System in the effects loop, and have spent a lot of time trying different settings for the effects loop send knob (typically between 12:00 and 2:00) and the Nova System's input setting and output setting. If I bypass the effects loop, the distortion in channel 1 isn't significantly improved. Also, the ratio between the channel 1 and channel 2 master volume settings don't change. Although I do prefer the tone of the effects loop bypassed, I prefer to use the loop for effects and like the solo foot switch option. I use high quality cables and occasionally clean all jacks with Deoxite to make sure I have solid connections.
Also, I did the "Reeder Mod" on this amp, and it clearly made a big improvement on the channel 2. I doubt this has an impact on channel 1, but thought I'd mention that I've done it.
Any suggestions? Different V1 or V3 tube?
Description of Tube Functions (per the owner manual):
V1 A = CH2 Drive Stage
V1 B = Input Gain Stage
V2 A = 3rd Gain Stage
V2 B = 2nd Gain Stage
V3 A = FX Loop Send
V3 B = FX Loop Return
V4 A = Reverb Return
V4 B = Reverb Drive
V5 A = Phase inv/driver
V5 B = Phase inv/driver
V3 A = FX Loop Send
V4 B = Reverb Drive
