No power to tube fan?
ATR1
Hello,
Mark V 90w combo amp.
I noticed yesterday my fan stopped working cooling the tubes. Watched video on fan replacement. I ordered a fan. This morning removed the fan in question and tested with a 9v battery.
Fan was working fine?
Need help to troubleshoot why my fan stopped getting power?
Thx
Is the fan switch off? If not, then perhaps check the fan leads from the unit for a voltage between 9-12vdc. If it's low then maybe there's a problem the 12v circuit which the fan voltage is tapped from. It's been a known issue on V:90s that the bridge rect diodes can fail.
Thank you my friend! I will search out a amp tech or send back to MB.
